Amp location????
Old 01-10-2008, 01:02 PM
Almost a Member!
blp320's Avatar
Mercedes ML320
Amp location????
I need to know where my factory Bose Amp is located
Old 01-10-2008, 01:39 PM
Almost a Member!
charliehustle's Avatar
2001 ML320 fully loaded except the damn navigation sytem.
I might be wrong, but i think its under the passenger seat if thats it.
Old 01-10-2008, 02:08 PM
Almost a Member!
blp320's Avatar
Mercedes ML320
I have the safe there..... is it under it???
Old 01-10-2008, 02:59 PM
West Town's Avatar
'99 ML320
From what i understand thee bose amps are in the doors, though i would have guessed that "it" was located with the woofer under the driver seat...
I wanted to take the woofer out and put in a second "safe" but was told the system may not work if i did so.
just guessing though.
Old 01-11-2008, 10:55 AM
Almost a Member!
blp320's Avatar
Mercedes ML320
cool thanks i'll check it out.
Old 01-13-2008, 02:54 PM
Almost a Member!
well, if thats the case, then what is that under the passenger seat. I know the sub is under the driver seat, but there is something under the seat where wires are running to snd from there. And no its not a nav drive.
Old 01-13-2008, 03:26 PM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
in your 98 ML the amp is located behind the drivers cup holder, in the dash... after the revamp it was located under the front passenger seat...
are you installing new door speakers or just a head unit? I can give you a work around if you want to just install a radio
Old 01-14-2008, 09:17 AM
Almost a Member!
blp320's Avatar
Mercedes ML320
redoing everything
Rate This Thread
Rate This Thread:
Quick Reply: Amp location????
