E-Class (W211) 2003-2009
Heater not working NEED HELP
Old 01-03-2008, 09:54 PM
b_rashed's Avatar
2007 S550 (S65 Package)
My heater stoped working guys. only cold air comes out. what could be the problem? somebody told me that it could be something called the heater control valve. anybody know about this problem.
Old 01-03-2008, 10:08 PM
Benz-O-Rama's Avatar
Eurocharged 2004 E500, Eurocharged ECU/TCU 2005 SL600, 2010 Caddy SwaggerWagon
DAMN MAN! Seems like every week it's something with that car. You parking it near magnets or something?
PM Konigstiger. He'll be able to arm you with the information you need to get it working.
Old 01-04-2008, 01:54 AM
Ed_284's Avatar
Heater Problem
I had the same problem with my 03 E500. It was the heater control valve. After doing a search on "heater" in the W211 forum I was able to find the part#.
The part cost like $50 and the labor was quite easy. Thank You MBWorld!
-Ed
Old 01-04-2008, 01:57 AM
Diesel Benz's Avatar
Should search for more posts as suggested above. One thread showing the heat exchanger shutoff motor here:
https://mbworld.org/forums/showthrea...exchange+motor
Old 01-04-2008, 03:09 AM
6hift's Avatar
Yup heater control valve. The part at my dealership cost me know more than 30 dollars (I get a discount). I repaired it my self and installation I give it a 5 out of 10 for someone with experience.
You have to remove a couple of panels, both wiper blades, and other little moldings here and there. Other than that pretty simple just watch out for the winshield clip.
Old 01-04-2008, 03:20 AM
b_rashed's Avatar
thanks guys, i guess that damn labor is gonna get me so im going to be spending around 150-200 bucks AGAIN. im getting really sick of the damnn problems with this car to tell the truth. i wish i could sell it but i wont make any money on it cuz of the upgrades i got for on it. i dont know if im even gonna fix it but thanks again guys.
Old 01-04-2008, 08:27 AM
vettdvr's Avatar
03 E500 and Corvette
Things to expect for either warranty or you pay. So don't be suprised.
Ball Joints
Brake pads every 30K
Heater / water control valve don't know the mileage but I have replaced 1
Ignition key switch
Alignment, tire wear
Maintenance average $500/visit at the dealer.
Just my observations so plan your $$ accordingly.
Old 01-04-2008, 08:59 AM
tonydr00's Avatar
2002 CLK 430
Talking
I had the same problem only getting cold air but that was after i removed the dash and forgot to connect the little plug in the back
Old 01-04-2008, 10:54 AM
Cars are clearly too sensitive these days
Old 01-04-2008, 10:58 AM
Can you remember if you replaced it with a part that had the new number:
A2118320584? Hopefully this one lives longer.
Would like to know the EIS issue, perhaps too much off topic.
Old 07-15-2008, 08:25 PM
mere320's Avatar
2004 E320
Are there any special tools required or anything special to worry about (ie releasing vacum presure etc.)?
Old 07-18-2008, 02:14 AM
t76turbo's Avatar
05 clk 55 conv., 03 E500, 01 E55, 03 F350, FJR1300....
Heater control valve. Had the same problem. Crapy design by MB, water/coolant enters the small electric motor in the valve and corodes the terminals. One of the few parts on a Benz that is actually cheap to replace.
Its located under the driver side windshield wiper (under the plastic cowling).
You will have to remove both windshield wipers, then unclip the plastic cowling, remove wiper motor and linkage, undo clips holding coolant lines in place (needle nose visegrips work prety well). Its tight in there but not too difficult to do. Takes about 1 hour.
Old 07-18-2008, 02:33 AM
W211 Ryda's Avatar
2004 E320
no special tools required...here is a simple DIY i posted last month.
https://mbworld.org/forums/showthrea...&highlight=diy
Old 07-18-2008, 04:31 AM
BRABUS_E500's Avatar
2005 E500 with 'some' BRABUS upgrades
My heater acts up every now and again. I guess I need to look into replacing that Heater Control Valve.
Good luck and hope you get it fixed.
Old 09-08-2008, 03:50 PM
mere320's Avatar
2004 E320
Thanks for the info and links to the threads. I'll definitely try this and let you know how it works out.
Old 09-08-2008, 03:57 PM
Almost a Member!
TheRealG's Avatar
a car
no one suggested checking your coolant level?
that is the first place I'd start (as per 'general automotive knowledge'), and then I'd see if the thermostat is bad.
I understand the valve seems to be a common fault, but there could be other reasons too... (just saying)
good luck!
G.
Old 09-10-2008, 12:16 PM
mere320's Avatar
2004 E320
Thanks for all of your help, especially W211 Ryda. Your photos and directions really helped.
Took me about 2 hours, probably because I'm always paranoid about breaking something.
Did the project, heat works great!
Quick Reply: Heater not working NEED HELP
