How to change oil in a CLK55 ???
Old 12-21-2007, 01:51 PM
fourml8r's Avatar
2005 CLK55 AMG CABRIOLET
I previously used the Topsider method (Suck oil out through dipstick tube) in my 2001 SLK320. That method worked fine (Instead of paying dealer $125). I just purchased a CLK55 AMG Cabriolet, how can you do this if there is no oil dipstick to suck the oil out from?
Old 12-21-2007, 07:11 PM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
What does your having or not having a dipstick have to do with it? If no dipstick then the common sense method takes place. Forget your suction method and take it to a local place like Jiffy Lube,drain the oil,chg the filter,and then add 8 qts of Synthetic oil. I don't know what more you'd want us all to tell ya.
I sometimes chg it myself but I know the car takes 8 qts of oil after fully draining the motor. The filter is easy to chg as well. Do it this way and you'll only be paying for the cost of oil and filter.
Old 12-21-2007, 07:59 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
The Dipstick Tube IS there ... NO Dipstick...Just the cap
Old 12-22-2007, 10:01 PM
spr
spr's Avatar
look at the capacity also note 2 drain plugs and use the computer for how much more to add if any should be fine.
Quick Reply: How to change oil in a CLK55 ???
