Bluetooth for 02 ML500
Old 12-01-2007, 01:55 AM
Chemaly's Avatar
2002 ML500 Sport
Hi,
I have an 02 ML500. There is no present phone cradlle in the car.
When I press phone on the head inut it says no phone conected,
How do I go about integrating a bluetooth system ???
Old 12-02-2007, 05:48 PM
Philip LeBlanc's Avatar
2012 E550 Convertible, 2009 Audi Q5 3.2
You can do one of two things: you can buy a factory phone system and install it (can be found on eBay or elsewhere), then buy the MB bluetooth adapter or you can visit www.eurocarphone.com and get the Argos device which will give wireless connectivity via your MCS unit. I have the factory equipment in my M Class with voice control. It works very well as expected. I have a buddy who has the argos in his ML500 and it works as well. Hope this helps.
Old 12-03-2007, 11:37 AM
Chemaly's Avatar
2002 ML500 Sport
I will check out the Argos
Tks
Old 12-03-2007, 12:11 PM
FrankFi's Avatar
2003 ML-500
Just a note on the Argos - I just installed it in my 2003 ML500. If you never had a phone before, you are going to need a Mercedes part, the so-called Y cable from the completion kit, to install the Argos. EuroCarPhone can sell you the D2B cable, which is part of the Y-cable, but they don't have the non-fiber part. I couldn't get this part from the dealer (and I tried my own dealer and various online dealers), but it may just be that the part number I was using has been updated. So, I bought an older phone completion kit from a classified ad that included the cable. The cable for the 2001-3 M Class is part #Q6820672, but the 2000 year cable works too.
Paul H. Dick's website has great information on installing a phone and on the M-class parts: http://home.earthlink.net/~phdwebsit...ted_phones.htm. This publication shows the cable connections: http://phdwebsite.powerpulse.cc/V60i...ual%20v4.6.pdf.
Good luck, and I'd be happy to provide more hard-earned tips if you decide to go the Argos route.
- FrankFi
Old 12-03-2007, 01:23 PM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
major advantage argos has is phone compatibility over oem solution...
i have parrot kit on my ML and MHI kit on my C.
had argos on C b4...
argos is prolly the best alternative to oem...
Old 12-23-2007, 04:42 PM
boldt's Avatar
2002 Mercedes-Benz ML55 AMG
Great info. I'm going to try this on my 02 ML55.. I have a new iPhone and hate the fact there is no bluetooth speaker phone in my truck!
Old 12-23-2007, 04:49 PM
ruey220's Avatar
ml55, Ml63, Porsche, C63S ED1
before you do that I strongly suggest you get an Alpine W205 with bluetooth.
You just have to chip in a few more $$$ but it will be worth it.
This will give you the following but not limited to:
portable nav that you can remove if you get the nav upgrade.
put a dvd player in the front
you can sell your nav to someone that didn't get it for at least $200.
if you do the factory parts, you still won't get that back if you sell the car as nobody will care about it being factory since the car by then would be so old.
Old 01-02-2008, 12:52 AM
s4play's Avatar
01 S2000, E46 M3, 99 ML320
I have a Motorola Bluetooth kit in my ML but recently found this kit which works just as well but even more stealth.
Read my s2000 install thread here if this helps!
rick
http://www.s2ki.com/forums/index.php...&f=26&t=550066
Quick Reply: Bluetooth for 02 ML500
