Seat Control Module
Old 11-12-2007, 05:51 PM
Almost a Member!
ballot's Avatar
C320
Seat Control Module
The seat control module in my 2001 C320 is causing a drain in my battery. I want to investigate this issue by looking at the module itself. If you have instructions on how to remove the module from under the seat, instructions for opening it up, and schematics, please attach them in this thread.
Old 11-12-2007, 06:32 PM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
it is a common problem...
not sure if u can repair it...
Old 11-12-2007, 07:04 PM
coin's Avatar
'06 CLK500
I am not sure if there are posted instructions here.
But this problem is covered under the Starmarked extended warranty.
Old 11-12-2007, 09:37 PM
WaveyKat's Avatar
Something Slow
had mines replaced at the dealer!
Old 11-12-2007, 09:48 PM
Moderator Alumni
TruTaing's Avatar
w203 m112
Taking the module out is really easy.
IIRC:
Unplug a few plugs that you can see from the under front of the seat(s).
Push a few clips around and pull. It should come out really easily.
As for diagrams of the thing itself. I dunno? You can get a new module shipped to you for about 200 bux.
Old 11-12-2007, 10:17 PM
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
yup happened to my 02 C320, is a really common problem, just unplug it then you will be fine, when you need to adjust your seat, plug it back in, cake...
but in the end my SA trick the dealer had my module replaced for free even my car is out of warrenty
Old 11-12-2007, 10:38 PM
Almost a Member!
ballot's Avatar
C320
Sweeeeeet. How did you manage to tick them?
They should have a recall on these unit. Everybody is complaining about them
Old 11-12-2007, 10:42 PM
KIRA's Avatar
recall only happened if is a safety reson
and as for the trick
you need those "asian connection"
Old 11-13-2007, 11:19 AM
ML55CLA45's Avatar
2001 c320 - 2002 ml55 - 2011 c300 - 2014 slk350 - 2015 cla45
if you are interested... i have a new drivers seat control module... i found the recipt recently and i purchased it from the dealer for 300 something...
i purchased it b/c of seat problems i was having... but it ended up being a motor....
contact me if you interested
-carino
Old 11-13-2007, 01:29 PM
sstcobra's Avatar
2002 C320 Sedan
The passenger seat on my 2002 C320 does not travel back more than half way. I have looked for jams in the track and have found nothing out of the ordinary. Can someone tell me if this can also be a control module problem?
Old 11-13-2007, 04:36 PM
ML55CLA45's Avatar
does the seat move in any other direction? this was the same problem with my drivers seat..... it would move in all other directions but not back... it ended up being the motor
Old 11-13-2007, 05:19 PM
sstcobra's Avatar
2002 C320 Sedan
The seat moves in all directions the full travel, except sliding rearward.
If it is the motor, what in a faulty motor would cause this????
Old 11-13-2007, 09:36 PM
Almost a Member!
ballot's Avatar
C320
The seat moves in all directions. Its just the module staying awake and causing a drain in the battery. Is there a specific chip/IC on this module that's causing this?
Old 11-14-2007, 10:00 AM
ML55CLA45's Avatar
well.. like i stated before. my seat would not move back at all. operational in all directions except reverse. i initially thought that it was the control module and purchased one. the module did not correct my problem. i took my car to the dealer and they replaced a seat motor that was dedicated to reverse.
i dont know what exactly in the faulty motor would cause this... besides the plan fact that the motor went bad....
Old 11-14-2007, 10:02 AM
ML55CLA45's Avatar
sounds to me that you need a new module. there might be a new chip/ic but i dont know how you would just change it specifically...
Old 01-13-2008, 02:41 PM
johndddd's Avatar
2023 C300w/AMG package
IIRC:
I’m having battery drainage problems too. I just unplugged the leads to the modules in both seats and recharged my NEW BATTERY. However I’m confused here, when the key is out of the ignition there is NO POWER to the seats. So how can the controllers drain the battery? Also I am trying to verify if you have to change both or just one. I wanted to start with the passenger side and see if this solves the problem. Does anyone KNOW FOR SURE if you have to change BOTH?
Respectfully
Old 01-13-2008, 03:15 PM
Marky Bends's Avatar
c320
Hmm, my battery has been draining too. I unhooked the seats but it still happens..My mechanic is pulling his hair out trying to find the cause of the drain.
All I can think of is I think this problem started after I tried to give someone a jump. I've done lots of reading on this problem but..Any ideas?
thanks.
Old 01-13-2008, 03:55 PM
johndddd's Avatar
thanks.
from what I have gathered seat module or dome light unit in from of your rear view mirror.
Old 01-16-2008, 08:07 PM
acedking90's Avatar
2001 C240, 2000 S430, 2002 ML320
Could you please emphasize on this? I have a drain somewhere too, its impossible to find, the dealership says its the radio module...which is a light 5 grand.
Old 01-17-2008, 07:18 AM
johndddd's Avatar
Good morning:
It could be anywhere, however the most likely culprit is your seat control modules, these are located under your seats. They control the movement. They are electrical parts and have a life-expectancy. Heat work on electrical parts, when you park your car outside in the summer months it has a toll on electrical parts then they fail. Unplug your seats, there will be a 3 conductor cable I believe its a #14 wire in the front of each seat, then see if your battery drains after 3 days or so. If this solves the drainage probem thats the culprit. In my case it was not. It was an aftermarket sub woofer that was not shutting off. However the seat modules go bad often. There have been several post of members having to change them out @ 1k parts and labor. I have 2 modules NEW IN A SEALED BOX if this is your problem. They sell for 300 each I have them for sale @ 500. Again NEW NEVER OPENED BOX.
Old 01-17-2008, 02:46 PM
Moderator Alumni
TruTaing's Avatar
w203 m112
1k in parts + labor is ridiculous :x That is ALOT of labor.
It takes almost 20 minutes to swap them out if ya know what you're doing... the process took me about 30 mins to swap mine out. I guess it also took a few 10 minute sessions to unplug fuses and let the car sit for a day though. Also it only took my broken seat module one day to drain my battery....
Old 01-18-2008, 03:38 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
here's my write up on how to replace the control modules.
I recently replaced mine and it solved the drainage issues.
https://mbworld.org/forums/c32-amg-c55-amg-w203/225393-c-class-seat-modules-compatible-c32.html
Old 01-18-2008, 08:02 AM
johndddd's Avatar
thanks for that info, now I know the modules that I have for sale will work on a C32 as well.
Quick Reply: Seat Control Module
