Problem with 01 s500 CD CHANGER
Old 10-17-2007, 09:21 PM
exit521's Avatar
2001 S 500
New to this so please forgive me for mistakes.
i recently bought a 01 S 500, and started havign trouble with my CD Changer,
first it would say no magazine, then some times it wouldn't read disks which were already in the magazine. The magazine got stuck in the changer, i took it apart, got a magazine out but now I have no sound, it says that there is no CD Changer in the car, there is no telephone in the car. I read some blogs and came to a conclusion that since the CD Changer is bad my volume is out, but i dont understand why aren't phone and volume working. I would appreciate it, if someone could guide me as to how to get this problem resolved.
Old 10-31-2007, 02:46 PM
nathan.nice's Avatar
S500
Similar Problem CD CHANGER- 01 S500
Hi there - I also just bought an s500 01, and am coming across a problem with teh CD Changer. I hopped in my car and it wouldnt play the disk. So i turned it off and on with no luck. It would just sit on CD1 and track 1 and not play. it would not allow me to change CDs either. it would let me look at the other cd's but when i clicked on another nothing would happen. i switched out cds even removed disc one. still the same problem but with disc 2 not playing. i would push FWD and it would stick like that. eventually i kept pushing buttons and it went all black and and reset playing the music like nothing happened. Can anyone please advise me on this?
Thanks,
nathan
Old 11-02-2007, 05:58 PM
Almost a Member!
jyalda6's Avatar
mercedes s500 w220
Thanks,
nathan
I have a 2000 s500 and my cd changer is giving the same problems it will start playing one disc but wont let me change through the tracks and its so sensitive to bumps anybody know what it might be thanks in advance
Old 03-14-2010, 10:33 PM
ZeeMee's Avatar
2000 S500 1997 E420/320
ok seems like thers no reply for a fix on this issue, I also have NO CD CHANGER on my command unit, and no phone but the radio works fine? what gives?
Old 03-15-2010, 12:08 AM
tusabes's Avatar
Mercedes
I have this issue too... it says I have no CD Changer and Cant read NAV disc, but the Tape and Radio work just fine.
Is there a reset procedure somewhere? Anyone know?
Old 03-15-2010, 12:14 AM
ZeeMee's Avatar
Ha, dude seems like everyone on this thread since '07 has the same problem but no FIX?
Old 03-15-2010, 05:20 AM
stevescoots's Avatar
w220 s600
yep, my CD player also occasionally comes up with no disk. its particuarly bad on home burnt CD's. I found that i had to eject the cartridge and put it back in again.
in the end i just hooked up my Ipod
Old 03-15-2010, 03:49 PM
ZeeMee's Avatar
Mine just says No CD changer, what's the fix
Old 03-15-2010, 07:40 PM
LAWYER2's Avatar
15' W222
You have to take the thing out and apart and literally FIX it! There's a tutorial floating around here or on benzworld that shows you how. Personally I thought it was just too much work and not worth the effort, plus I use my iPod and don't bother with CD's anyhow
Old 03-16-2010, 12:32 AM
ejack's Avatar
2001 Mercedes s500 amg sport
Exit 521:
I'm sorry to hear about you recent misfortunes. It sounds as if your faulty CD Player has broken the continuity of your fiber optics communication loop. Hence all equipment that
requires an unbroken loop is reporting a failure (tel., radio, etc.). Similar problems have
been solved by disconnecting the power to the CD player (via the trunk), and bypassing
it using fiber optic cables. There was a detailed thread explaining this procedure circulating about one year ago. Perhaps Skylaw, could shed more light on this problem and its solution.
A good Non-Dealer shop could resolve the problem in about 15 minutes at a price of approximatedly 50.00
Good Luck
Old 03-16-2010, 08:46 AM
tusabes's Avatar
Mercedes
anyone have a shop recommendation in san francisco area? I would love to get my CD and NAV working for $50
Old 03-16-2010, 08:01 PM
suggashane410's Avatar
clk,s-500
Mine did the same thing, unhook the battery, wait 30 mins then hook back up. If that doesnt work,do it for 2 mins, then disconnect the big plug on the amp and re hook it, check the fuses too...
Mine got wet and i had no sound but after i dried it off and did all that,it works, check the battery voltage..a low battery will mess alot of **** up..i know from experience
Old 03-20-2010, 02:35 AM
ejack's Avatar
You might want to try calling Keith Valentine, an MB telephony specialist in the California area . He sells MB telephony components on ebay as "Cellguy85" His posted cell phone number is 714-746-5930.
Please tell him that you were referred by autoseeker2eighty6 (ebay handle) from Brooklyn, N.Y.
The 50.00 quote price was from mbdoctor.com from Brooklyn, N.Y.
Old 03-20-2010, 11:37 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
The Audio Problems section of the new post at https://mbworld.org/forums/s-class-w...tart-here.html may help you - and it has the repair blog that was "floating around." It also has a possible substitute for the OE unit if you need to replace it.
Quick Reply: Problem with 01 s500 CD CHANGER
