SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: '85 380SL Rear View Mirror Removal
Old 09-22-2007, 02:01 PM
jnappi's Avatar
I read that the interior rear view mirror is held with 3 ball bearings and that you must force it down and to the side to remove the mirror. I have tried that with some force, but I am afraid of breaking the post. Has anyone been successful in removing the mirror and can you share your method with me?
I am replacing the visors and the end clip on the drivers side is does not hold the visor all the way up. I would like to replace it.
Old 09-25-2007, 10:27 AM
jnappi's Avatar
I did it! After reading some archived advice, I was able to remove the mirror. The best advice I got was to first spray some WD40 around the base of the mirror. But, what really helped, was the advice to wrap a towel around the entire mirrow and post and wiggle the mirror from side to side (Not front to back). The towel give you much more leverage.
I installed two new sun visors and that was a project itself. If anyone needs help installing new visors, let me know, I have some pictures and have done it.
Thanks all!
Old 09-26-2007, 10:44 PM
StingrayL82's Avatar
1979 450SL
If you could post pics of the sunvisor replacement, I would be most thankful.
Quick Reply: SL/R107: '85 380SL Rear View Mirror Removal
