1999 ML430 Need programming help for Keyless Entry
Old 07-19-2007, 12:26 AM
marinabay402's Avatar
1998 SLK230; 1999 ML430
I need to program a new remote for my 1999 ML430, anyone have the instructions? Thanks.
Old 07-26-2007, 07:40 AM
Bighouse's Avatar
1999 ML 320
I have a 99 ML320. To reset/program the key my manual says to insert the key into the ignition and turn it to position 2. Then remove the key and within 60 seconds hold down the lock doors button and press the unlock doors button 5 times.
Would be interested to know if this works.
Old 01-31-2011, 12:42 PM
MikeC825's Avatar
ML430 1999
remote procedure
Did this procedure work with your 99?? Thanks
Old 02-11-2011, 11:37 PM
c3212571's Avatar
2002 Mercedes c32 1998 Toyota tacoma 2002 Honda Cbr600f4i
stick key in ign.
pull it out
get out of car
shut door
first make sure your batteries in remote are good
1.hold down lock button
2.while lock button held down, hit unlock button 5 times
3.release a buttons and hit any button
*1-3 steps need to be done within 5 seconds!
Old 02-12-2011, 11:41 AM
Mike's ML's Avatar
1990 190E 2.6, ... 1998 ML320, 2005 ML500SE
If you have a new key the remote's keyless entry and alarm can be programmed by you with the instructions given above.
However the DAS function can only be programmed by the dealer.
If you purchased the key from EBAY all I can say is good luck. The dealer will do nothing for you. If you purchased from a Mercedes dealer they should have programmed all the functions for you. The Dealer needs both a new factory supplied key and the vehicle to marry key and the AAM's/DAS security codes together.
Mike
Quick Reply: 1999 ML430 Need programming help for Keyless Entry
