SL/R230: Help! Problems with Convertible Top...
Old 07-16-2007, 02:49 PM
jd985krz's Avatar
My 2003 SL 500...
I put my top down the other night.. It got down maybe 90% and it stopped. I got a red light that said visit workshop.. It totally lost power, wont go up or down..
I figured maybe shutting off and starting the car would help it but now
It keeps saying "in operation" but nothing is happening... I dont hear any noise when im pulling or pushing the convertible lever.......
Any help would be great..
Old 07-16-2007, 11:10 PM
djamer's Avatar
SL 500
Originally Posted by jd985krz
My 2003 SL 500...
JD.
Refer to this link:
http://www4.mercedes-benz.com/e/cars...60.html#N21BB8
review the troubleshooting for Roof operation. May require you to call your dealer and let them look at it.
Old 07-17-2007, 03:17 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
My 2003 SL 500...
This could be a stuck microswitch. The ones that detect the position of the folding flaps and the ones that detect the trunk lid assembly latches can cause the mechanism to freeze and become inoperable as you describe.
You can diagnose this yourself with a basic electronic multimeter by checking the inputs to the top controller; or if you have the proper scanner, you can read diagnostics. If you take the car to a dealer or well-equiped independent, they should be able to diagnose the problem quickly and easily.
Old 07-17-2007, 03:31 AM
ToughSuccess's Avatar
2006 Mercedes Benz SL55 AMG
I had the same issue, make sure to visit the dealership asap and I pray for you the car is under warranty.
Old 07-17-2007, 05:10 AM
mjr24's Avatar
M6 Gran Coupe
How about being a little more specific....you said you had the same problem. So what WAS the problem and what did it cost?
Old 07-17-2007, 01:22 PM
djamer's Avatar
SL 500
without a warranty, the hardtop hydraulic pump runs around $3500 with labor, from speaking to a service advisor. hopefully it's not the pump and some switch issue. good luck.
Old 07-17-2007, 03:29 PM
The problem was the top wouldnt go up or down because the one of the wiring harnesses were not relaying information to the top to open and close and it didn't cost a penny because my car is under warranty. Otherwise the invoice that I recieved showing the cost of all the work done with parts and labor show a $3,200 bill.
Old 07-20-2007, 08:38 AM
allminesl550's Avatar
My 2003 SL 500...
Somewhere at that link posted by Djamer there is a section called "Lowering the loading aid manually". It describes what to do if, for instance, your folding roof is folded in the boot and you went back there and hit the button to raise the roof a few inches to access the trunk space, then hit the button again to lower the roof in but it didnt come down properly.
Now i realize your problem is not exactly the same, but nevertheless (if you have no warranty/$$) it may be possible to temporarily solve your problem by following the same or similar simple proceedure, which amounts to turning some allen screw one quarter turn ccwise while your friend holds and supports the roof while hopefully it comes down completely. Then turn the screw back to original position, of course. The screw is located under the boot floor to the left.
http://www4.mercedes-benz.com/e/cars...E1.html#N226BF
Old 07-20-2007, 09:01 AM
mjr24's Avatar
M6 Gran Coupe
I'm taking it to my Benz mechanic. I strongly advise against temporarily rigging something or screwing with something on a $100k car-especially as delicate as a convertible top.
Old 11-10-2013, 04:07 PM
samplelogistics's Avatar
03 sl55 amg
My 2003 SL 500...
you have two flaps one on each side of the underside of your trunk lid these flaps are called elephant ears, they move In and out during the operation of the top. If one of the flaps is not fully engaged the top will not open or closed and it will seem like it has no power. this has happened on my SL 55 I took it to a certified Mercedes mechanic and it cost around $650 to fix most likely this is your problem.
Quick Reply: SL/R230: Help! Problems with Convertible Top...
