Multi-contour seats
Old 10-13-2002, 01:56 PM
jhillman's Avatar
2017 AMG C63S Coupe
Multi-contour seats
If you get the multi-contoured seat (driver's only) on the C class, does the driver's seat look different from the passenger seat? Also, where is the control mounted for the multi-contoured seat?
Any pictures??
Old 10-13-2002, 06:04 PM
Bobdole's Avatar
C32
what type of option is that wasn't available on the 02 c230
Old 10-13-2002, 06:17 PM
AndrewK's Avatar
Audi S4
I'm not sure about the W203, but on the W208 CLK the seats do not look different and the control was mounted next to the seat belt buckle.
Old 10-13-2002, 10:36 PM
patronus's Avatar
2001 C240 / 6-speed
Ditto the W203.
Old 10-14-2002, 02:10 AM
jhillman's Avatar
2017 AMG C63S Coupe
Question
So...then I'm assuming there is no change in the appearance of the seats with multi-contour compared to the standard seats? Otherwise, I would imagine the passenger and driver's seats would look different, as the multi-contour is a 'driver's seat only' option.
I was hoping the multi-contour seat would provide for better thigh bolsters thus giving more lateral support to the driver.
Anyone have pics or know where I can find pics of the seats and the multi-contour control? I have no idea what this looks like. ??
Old 10-14-2002, 03:27 PM
patronus's Avatar
2001 C240 / 6-speed
OK, specifically the W203 passenger and driver seat look IDENTICAL with the exception of the control unit residing just beside the driver's seat belt anchor.
Old 10-14-2002, 05:55 PM
shtatc's Avatar
2001 C240 6spd
I have the multicontour seats in my car - and YES you are correct - it is drivers side option only. There is no difference in the looks of the seats or the design.
The answer here is NO - you do not get more thigh bolster - the 4 adjustments are: 1. raises front part of seat under thighs. 2. lower lumbar support. 3. Upper lumbar/lower thoracic spine support. and 4. lateral side support. However, the lateral support does not keep you in the seat enough. I saw the C32 seats - they seem alot more supportive in this regard.
Sorry - I cant send pics - but the adjustment switches are on the right side of the seat, betweent he seat and centre consel. Sometimes I hit the switches when I attach the seat belt buckle - they are fairly close together.
Old 10-14-2002, 06:20 PM
jhillman's Avatar
2017 AMG C63S Coupe
Are the controls lighted?
Old 10-14-2002, 07:10 PM
shtatc's Avatar
2001 C240 6spd
Sorry - no lighted controls.
I think MB could have designed the entire control unit a little better. Kind of cheesy/cheap if you think about it. If they could have put it on the seat itself, I think it would have been better.
Old 10-14-2002, 07:46 PM
Almost a Member!
njoyaz's Avatar
2002 C320 Bril Slvr,NAV
I had a 2001 C 320 without multi-contour and wasn't satisfied with the seat
comfort so on my 2002 C320 I ordered the multi-contour feature. Franklly I
will not order it again. The seat cushion extension mainly inflates a bag at
the front that makes for an uncomfortable roll under your legs. The side
bolster feature is ok. The back orthopedic bags are small like in the seat
cushion that put a narrow pressure on your back rather than covering a
larger area to provide good lumbar support. Save your money.
Quick Reply: Multi-contour seats
