Problems with ML320 Fuel Gauge
Old 05-18-2007, 10:10 AM
mymckoy's Avatar
I have a Mercedes ML 320 2001 - just recently the fuel gauge doesn't register when new gas has been added. It has been to the Mercedes dealer 2 times in the same week - first they rest the gauge - the next time they reloaded some software - went back to the gas station to see if it is fixed - still does NOT register new gas. Once reset it will correctly deduct gas reading from the gauge but when it is refueled and FULL - won't recognize the full tank on the fuel gauge - please help!!
Old 05-18-2007, 01:10 PM
///AMG55's Avatar
XLR
You need to change you're fuel gauge assembly with fuel lines the whole shebang-a-bang that sits in the gas tank. Its under your driver-side rear passenger seat, a lot of labor. It happened to me too. no biggie.
Old 05-18-2007, 05:16 PM
PaulX608's Avatar
2011 VW cc, 2004 ML350
Welcome to MB World, and welcome to the dreaded ML fuel sender issue. If you search the forums, you'll find that quite a few of us have done this job ourselves. My SA said it would be $750-$800 if they did it. My son and I did it in a three hours or so for $350 in parts.
Old 05-20-2007, 11:16 PM
Almost a Member!
charliehustle's Avatar
2001 ML320 fully loaded except the damn navigation sytem.
Well, lucky yall, i paid 1200 for mine. Well, actually the dealer told me that i needed a new fuel pump and also my three fuel lines were worn so i had to replace all three of those. Also, my power steering resivoir was leaking and that needed to be replaced. The good news was that my catalytic converter was cracked and my warranty covered only that. lucky me huh.
Old 05-21-2007, 05:24 AM
PaulX608's Avatar
The fuel sender is part of the pump and the whole assembly does indeed need to be replaced. Also, as you point out, if you still have the old style filter you'll need to replace it and the three lines associated. There's a bit of labor involved, but it's not really technical labor, just tedious.
Old 05-21-2007, 04:48 PM
benzeboy's Avatar
ml320 & c240
If you plan on doing it yourself check out ebay for the parts there is a fuel pump and fuel lines up for bids now and it is oem. save some $$$$$
Old 05-22-2007, 08:12 AM
CJ7
CJ7's Avatar
1999 ML430
my power steering was leaking also and my dealer replaced the hoses under warranty aswell as the cracked cat. and some other stuff.
Old 11-28-2012, 04:46 PM
egauster's Avatar
S550 4matic, ML350
ML 350 2009 Fuel Gage Problems
Went through at least 6 visits to the dealer with a fuel gage that dropped from half to zero then stopped working. The ECU was somehow reprograming itself to show fuel capacity at 8,000 gal + !!
The dealer replaced both fuel senders/pumps, instrument cluster, wiring, SAM module and still NO FIX... (all under warranty)
Finally- looks like the problem is the "Central Gateway"... which is now being replaced.....
We shall see...
Old 05-09-2015, 09:57 AM
royedwin's Avatar
98 Mercedes ML320
My 98 Mzb ML320 has a new fuel pump and the latest fuel filter 600.00 later the fuel gauage still does not work stays on empty......I would like some advice as to what to try next don't want to spend more money on this 17 year old vehicle....now using the trip ometer to keep control of my fuel consumption so I don't run out a pain in the ***
Old 05-09-2015, 04:19 PM
art_arev's Avatar
2003 ML55,2007 ML63
If the gauge was showing empty from the day the pump & filter were changed, then it could be few possibilities. The Fuel level sensor is on the fuel pump. Most probably during installation the arm of the floater has popped out, or it got jammed. Whoever installed the pump must remove it & reinstall it properly. The other possibility is while changing the fuel filter the X18/3 (next to fuel filter) connector was disturbed.
Of course, before removing the pump check that the electric plug on the pump & X18/3 is properly connected.
Quick Reply: Problems with ML320 Fuel Gauge
