Reset Service light
Old 03-22-2007, 12:11 AM
RUBYMARDIONO's Avatar
2014 C200 w204
Reset Service Indicator Light
Any body here know how to reset the service indicator on my Merc C200 Kompressor 2001 (W201), so I do not need to go to the stealership for service? Much appreciated.
Old 03-22-2007, 12:16 AM
kevblah's Avatar
E90 M3
Yeah, it says I got 400 miles until Service A or some crap. I need to reset this before it gets overdue.
Old 03-22-2007, 12:21 AM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
Anybody know where my cupholder is?!!!
E
PS, because I'm not a total c&ck, look up FSS reset.
DONT RESET THE LIGHT IF YOU DIDN'T DO THE OIL CHANGE
Old 03-22-2007, 12:24 AM
c230K415's Avatar
AMG GTS
Turn key to on position (the position right before it turns on your car)....hit the buttons to get to your menu on your dash that says "XXX miles until Service Y..."....hold the reset button till it is reset...
LISTEN TO E:
DON'T JUST IGNORE THIS...DO THE OIL CHANGE/MAINTENANCE REQUIRED...or we'll probably see you around more in a couple years...all for bad reasons too...
use the SEARCH FEATURE...it's very good...better to dig up a merged/old thread than to start new ones that junk up the place...specially if it's something that has been discussed several times (e.g. FSS Reset).
Old 03-22-2007, 12:31 AM
  #30
fckjdmsht's Avatar
c230 Kompressor
LISTEN TO E:
Wheres the Reset button?
Old 03-22-2007, 12:42 AM
  #31
Cloudz's Avatar
2007 C280 Avantgarde
somewhere listed in the forum, use the search function...
which really sucks because people keep asking about oil change, and when I was actually looking for some info, a 1000 matches came up... if people would just stop asking...
Old 03-22-2007, 12:45 AM
  #32
c230K415's Avatar
AMG GTS
that stick-like button that sticks out of the trim of your dashboard.
Old 03-22-2007, 03:27 AM
  #33
2014 C200 w204
LISTEN TO E:
Thanks, I will try
Old 03-22-2007, 07:57 PM
  #34
kevblah's Avatar
E90 M3
yeah, i got my car like a month ago and all that stuff was done before delivery, so i doubt i'll need an oil change already
Old 04-16-2007, 08:00 PM
  #35
S4toAMG's Avatar
c230
Reset Service light
ive searched and read through many threads i need to know the process of resetting the service light for an 06 c230 with a v6 supposedly it is different for this model year.. mercedes service want to charge me 125$ to do it as they say the software needs to be updated.
Old 04-16-2007, 09:28 PM
  #36
jan ken po's Avatar
'05 SS Brillant Silver
https://mbworld.org/forums/showthrea...=reset+service
Old 04-16-2007, 10:49 PM
  #37
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
That doesn't cover MY06+. Misinformation verboten.
Old 04-17-2007, 12:14 AM
  #38
jan ken po's Avatar
Sorry.
Old 04-17-2007, 03:15 PM
  #39
S4toAMG's Avatar
c230
does anyone haved the correct info on how to reset this
Old 04-17-2007, 03:29 PM
  #40
BIGjohnny's Avatar
/////AMG
Turn the key to on position (don't turn the engine on) and use your steering wheel buttons and click til you get A service or B service at XXXX miles. Then hold the reset button that is located on the instrument cluster, near the temperature gauge (should be on the left side). A note will appear and it'll inform you to hold the button again for another 3 seconds to reset the service mileage. Good luck.
Old 04-17-2007, 06:35 PM
  #41
S4toAMG's Avatar
c230
didnt work... is this for the pre 06 model
Old 04-18-2007, 01:11 PM
  #42
Almost a Member!
Brodie's Benz's Avatar
2005 C230 SS Kompressor
I tried resetting my service indicator as you mentioned from the previous thread but it only reset my mileage from the last start. The service B indicator remained. I have the Stealership do my oil change ($70) and I changed the cabin filter and completed the inspection myself. My brakes are still good to go. Is the stealership is the only one can do this? help..
Old 04-18-2007, 01:17 PM
  #43
c230K415's Avatar
AMG GTS
Have the key turned to the "On" position (when all the electronics turn on) and go over to the screen where it tells you that "Service X in XXXX miles"...when you are at that menu...hold the reset button
Old 04-18-2007, 02:00 PM
  #44
Almost a Member!
Unhappy
Mann..it doesn't work...I contacted Escondido MB and I was told that I have to get my Service B with them to get it reset which I think is BS! or find an independent mechanic that has the computer to reset the message...That is $300 to be wasted...We the consumer should have the option and not to be stuck with STEALERSHIP to do our Service....I own a 5 Series BMW and never encounter such BS..I am thinking of getting rid of this car and get me new 3 Series....
Old 04-18-2007, 02:20 PM
  #45
yeuchau's Avatar
Stage 2 C7 A6, QX60
but if you want to be safe, just do an oil change
it's not gonna cost you a lot
Old 04-18-2007, 02:38 PM
  #46
S4toAMG's Avatar
c230
anyone know? is the dealer the only place that can reset this
Old 04-18-2007, 05:35 PM
  #47
Almost a Member!
If you have similar experience with this particular issue, please share them. I am sure others would like to hear you what you want to say.
Old 08-23-2007, 07:07 PM
  #48
Almost a Member!
fresh240's Avatar
c240
oil change
heyy i recently had an oil change and they didnt reset on the computer in the dash if could help me i would appreciate it
also checked the manual couldnt find anything maybe its just me
Old 08-23-2007, 07:13 PM
  #49
Super Moderator Alumni
drexappeal's Avatar
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
please stff...it has been discussed. I was told that you may not need star diagnose to reset the Service A/B indicator. That's how I interpret your post, but if you were looking for information about the oil content reset, it automatically updates the content of oil.
Old 08-23-2007, 10:54 PM
  #50
wingless's Avatar
Debadged 6-Speed '05 C320 Sports Coupe
Didn't this work?
Quick Reply: Reset Service light
