Aftermarket HID Conversion Kits & required setting XENON=PRESENT thread
Rating: Thread Rating: 64 votes, 5.00 average.
Old 02-06-2010, 02:12 PM
  #1801
SheryarYO's Avatar
C63
Alright guys. I had HIDs installed and had the blinking problem. I bought the error eliminators and got the guys who installed my lights to fix them. They don't blink at all anymore, BUT they also don't turn on when I have the light setting on Auto. They only work when I have the lights turned manually on. Has anyone experienced this before and do you know why it's happening. I'm gonna take it back to them again, but I was hoping to have an idea of how to fix it before giving it back to them. Thanks.
Old 02-06-2010, 02:31 PM
  #1802
mynameiseldin's Avatar
07 C230 Sedan / 01 Mazda 626
Where did you order the HID's from?
Old 02-06-2010, 06:32 PM
  #1803
SheryarYO's Avatar
C63
i just went to a shop where they mod cars and asked them to install HIDs for me. i believe they used the Phillips Kit if that helps at all...
Old 02-06-2010, 11:59 PM
  #1804
londonbenzkid's Avatar
2002 C240, 2006 ML350, 2011 X3
Man... i have my 55w DDM slim digital kit installed...
I have xenon setting set, but sometimes when i start the car... only the passenger side comes on.. the drivers side flickers on and dies almost instantly...
To get the drivers side back on... I have to play around the settings mutiple times.. turning off all of the lights... switching from auto to full power etc... then finally I will get both lights to turn on... and it will stay like that.. WTF
I always get an error for Lowbeam LEFT (drivers side) not right side..... So confused..
Old 02-07-2010, 08:29 AM
  #1805
krisv420's Avatar
02 C320 Sedan
These will solve any issues.. Mine flickered badly but got a set of these and they work perfect.. No i didn't have to go to the dealer and set any crazy xenon on b/s.. Everyone makes our cars seem like there a spaceship and only nasa can work on them.. hehe
http://cgi.ebay.com/ebaymotors/HID-K...Q5fAccessories
Old 02-07-2010, 10:42 AM
  #1806
i had a set of those error cancellers installed as well.
it didn't do anything, so i took them out as the connnectors were not very tight and kept slipping out.
Old 02-07-2010, 06:51 PM
  #1807
W203E35's Avatar
2006 C350 Sport 6MT
The Xenon=Present isn't BS. There are many member here even with error cancelers have had flickering issues. When they set Xenon to Present it took care of the problem.
Old 02-16-2010, 11:30 AM
  #1808
GuidosGottaBenz's Avatar
05 C-230 Kompressor
Can anyone tell me if theres a HOW TO for a benz tech to follow on how to change the XENON=Present mode?
Old 02-16-2010, 01:47 PM
  #1809
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
STFF...its under the DIY section
Old 02-16-2010, 02:25 PM
  #1810
05 C-230 Kompressor
I did and couldnt find it....thanks dude for all your help!!!!!
Old 02-16-2010, 03:18 PM
  #1811
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Lookie what I found.. IN THIS THREAD:
https://mbworld.org/forums/2271523-post1096.html
Old 03-23-2010, 08:20 PM
  #1812
HMMMxxx's Avatar
2012 Class Coupe C250
Xenon = Present? anyone with the instructions to show the dealer?
Old 03-23-2010, 08:39 PM
  #1813
W203E35's Avatar
2006 C350 Sport 6MT
1 EIS- Electronic ignition switch
2 Control Unit adaptations
3 Read coding and change if necassary
4 All Codes
5 Xenon Headlamp - Change to present.
The member above your post get's the credit
Old 06-24-2010, 08:46 PM
  #1814
chkoo's Avatar
W211 E63, W205 C300
just had this done, working fine
before i had it i had to turn the headlight on manually for it to work
Old 06-28-2010, 09:44 PM
  #1815
sexyklammy's Avatar
'05 C230 kompressor
Hi everyone!
Just installed HID and I get flickering only on the passenger side light. Also get the left low beam is out when setting on auto. I think if I turn the car on at full power no errors. Anyone know why I only have 1 light flicker or has had it happen to you too?? will the dealer xenon=present solve this issue. Thanks everyone in advance for replies
Old 06-29-2010, 04:39 AM
  #1816
W203E35's Avatar
2006 C350 Sport 6MT
Originally Posted by sexyklammy
Hi everyone!
Get the Xenon=Present enabled and I'm pretty sure it will take care of it. A member here named Rollnnn had flickering issues and when I enabled his Xenon=Present he said the problem went away.
Old 06-29-2010, 07:36 AM
  #1817
Super Moderator
Glyn M Ruck's Avatar
Hi everyone!
Xenon=present will solve your flickering problem. Different behavior left to right can be caused by different power consumption lamps fitted L/R, different age lamps where one is battling to strike (an arc) or one lazy ballast. This all presumes your wiring is correct.
Strongly recommend fitting new Bix lamps of same make and max 6000 Kelvin.
Old 07-08-2010, 02:44 PM
  #1818
pcy
pcy's Avatar
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
Quick question on the HID conversion kits - will the power connector on the car fit directly to these HID kts? or do we need to cut-off/customize the connection?
Thanks in advance :-)
Old 07-08-2010, 03:36 PM
  #1819
jcnash's Avatar
2002 Mercedes Benz C230 Coupe
Depends on which HID kit you get but its a direct fit for most of them like DMM, VVME, etc.
Old 08-03-2010, 06:12 PM
  #1820
sexyklammy's Avatar
'05 C230 kompressor
Thanks for the tips. Does anyone know an independent shop or a dealer that will switch the xenon to present in the Greater Toronto area? I'm out in the city from time to time. I asked my dealer in my area but they don't seem to want to do it for me. Thanks!
Old 04-01-2011, 04:45 PM
  #1821
c240DUDE's Avatar
2002 C240 (SOLD), 2006 E350
For everyone who is having the blinking problem all you need is a resistor aka relay. Got mine installed for $20.
Old 04-03-2011, 09:20 AM
  #1822
Silver C's Avatar
C240
But wouldn't adding the resistor prevent you from having the bi-xenon functioning properly?
Old 04-12-2011, 04:05 PM
  #1823
c240DUDE's Avatar
The resistors help regulates the power output that our car produces. It ultimately depends on what setup you have. For example, OEM or aftermarket. I have a Xentec HID kit installed on my car. I bought it on ebay for a really good deal and installed them myself. Click here for the Ebay link
Old 05-05-2011, 12:51 AM
  #1824
purplecones's Avatar
2007 C280 4Matic
can i set the xenon=present option prior to installing my new headlights? Will the regular halogen lights still work fine?
Old 05-05-2011, 01:18 AM
  #1825
giannidy's Avatar
2001 C320
Yes you can and yes they still will work.
You have already rated this thread Rating: Thread Rating: 64 votes, 5.00 average.
Quick Reply: Aftermarket HID Conversion Kits & required setting XENON=PRESENT thread
