4Matic Front CV Joint
Old 03-14-2007, 04:10 PM
lexrex's Avatar
'98 E320 4Matic, '85 380SL
It must be that time of year when things start breaking.
My front CV boot is cracked and throwing grease all over the place. Has anyone w/a 4matic replaced theirs? What was the cost?
Old 03-21-2007, 02:39 PM
songtruck's Avatar
1998 E320 4matic front outer cv boot replacement
I noticed both were cracked last fall and after searching every where for a boot kit ( unsuccessfully) I had my local indie replace...288.00 labor and 72 per boot...yes that is 72 dollars each for the boot! I have replace many cv boots , axle shafts and the joints themselves on vw's so this came as a shock to me.
Old 03-21-2007, 05:38 PM
Franasia's Avatar
2000 E 320S4 210.282 4Matic Estate
I have been concerned about this since I am at 110k miles now and was wondering if it would be OK to replace all front CV boots as preventative maintenance. I find your cost to be rather reasonable as compared to replacing the axle for $1200 as I read on another thread if a boot goes bad.
Old 03-21-2007, 06:06 PM
lexrex's Avatar
$1200? Can you send me the link?
My boot has broken -- hence the grease. I'm hoping the axle can be saved. I've driven a total of about 5 miles since it started throwing grease. No clunking/clicking noises (yet) as is typical for CVs on their way out.
Old 03-21-2007, 07:53 PM
Franasia's Avatar
$1200
Here you are:
http://www.benzworld.org/forums/w210...hlight=%241200
Old 03-21-2007, 11:56 PM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
I actually did one of these not too long ago. It was the front passenger outside CV boot. Once you get the axle out it may take about 30-45 minutes to get the axle apart, cleaned up and rebooted. It's a pretty simple and straightforward job. Just don't pop the CV joints apart incorrectly or it can be a pain in the butt getting the small ball bearings back into place.
Old 03-27-2007, 09:10 PM
lexrex's Avatar
fixed for $230 parts & labor... thankfully no $1200 axle shafts required
Old 04-02-2007, 10:51 AM
Franasia's Avatar
Great news, $230 is excellent.
I took mine to the shop this morning and they found one has just cracked and started spitting grease. So just on time. It will be $290 per side parts and labor. Not too bad.
Old 08-22-2013, 07:17 AM
cachandler0126's Avatar
2005 S500 4Matic
Does anyone have a video of a front boot replacement? 05 S500
Quick Reply: 4Matic Front CV Joint
