Horrible whining noise when accelerating
Old 01-28-2007, 08:54 PM
comer7874's Avatar
2001 C240
Hello all,
I am new to the board and thought that I would seek the advise of other members before taking my C240 in. It recently started making an extreme high ptched whining noise after starting the car. The high pitch whining increases as i push down on the accelerator. It does this when I am in both drive, neutral and park. I have an automatic transmission. I was hoping someone might have some insight as what it could be. Since it makes the exact same high pitched whine when in neutral and park makes be believe that it might not be transmission related. Please help with any advice or similiar expreinces. Thank you for your help and your time.
Old 01-29-2007, 01:26 AM
Almost a Member!
flipnf3rno's Avatar
06 C230 Black/Black
This happened to my 06 C230 and the dealer took care of it. It was the pulley/bearing.
Old 01-29-2007, 01:49 AM
EV0LVE's Avatar
F10
possible loose belts. check belt tension
Old 01-29-2007, 02:02 AM
Moviela's Avatar
That is the sound of the BMW next to you attempting to keep up!
Old 01-29-2007, 11:48 AM
SlvrC230SS's Avatar
2006 C230SS & 2009 E350
It's the idler pulley. i had the same problem before and the dealer took care of it since it was under warranty.
Old 01-29-2007, 01:05 PM
comer7874's Avatar
2001 C240
My car is not under warranty any more. I am taking it in for a serivce at the same time. Any idea of how much that will run me to get the idler pulley replaced whiel they do the service? Thanks for your help.
Old 01-29-2007, 01:32 PM
c230K415's Avatar
AMG GTS
Old 01-29-2007, 03:31 PM
tee_tz's Avatar
ML63 AMG
Mini Coopers aren't really BMW's, oh unless it's the 1-Series, it's not a BMW.
Tee_Tz.
Old 01-29-2007, 04:01 PM
sirenebekim's Avatar
try spraying some wd40 on the bearings for the pulley's, that should take care of it. Also check to see if the belt is worn, or try some belt dressing like "No squeak"
Quick Reply: Horrible whining noise when accelerating
