2000 S500 vs. 2003 E500 (S class race against E class)
Old 12-15-2006, 01:24 AM
fusion2007's Avatar
CLS 63 S AMG , s500,clk550
Post 2000 S500 vs. 2003 E500 (S class race against E class)
ok this is wats up fellow S Class drivers. my friend has recently purchased an E500 and says he will beat my s500. which is probalby true he will UNLESS, all the expert s class drivers here can give me some tips. i have raced a little before buy not in my s class. This race is for the Pride in our S classes. Id appreciate if anyone has any information or tips to help the performance a little bit. I have heard of things like resetting the throttle or something thats connected to the ecu by like turning the igniton on and pressing the accelorater down to the floor for 5 secs then release and leave key in off postion for 2 mins.
My advantages so far are well he has no racing experience
and this is his first mercedes so he knows very minimal about it. hes probably not very good with shiftronic.
also if anyone has any info how to tweak the ecu chip that would be great
im thinking about adding a renntek package soon but im not sure if its even worth it.
Id appreciate any advice what so ever. as long as we can dominate. WE HAVE TO WIN!!! especially so i can shut his mouth once and for all.
Old 12-15-2006, 03:40 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
Thumbs down
Sorry man, I don't get it!
What are you trying to proof???? Why messing around in the controls of your beautiful sedan, and risk anything?
You have the S-Class and that's it. Smooth and quiet ride, top technology, luxurious interior, ............
Old 12-15-2006, 08:00 AM
sprink49's Avatar
2004 S500
Though I have not done this, it seems harmless enough:
1. Turn the ignition key to the on (not start) position.
2. Press the gas pedal to the floor and hold for five seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least two minutes for ECU to reset.
This re-sets the adaptive transmission programming ECU to it's default setting. If most of your driving is sedate and normal (like most people) your ECU has adated your programing to your style. The reset will remove that from memory.
The guys on the E55 forum swear by this method.
Do a forum search for "Adaptive transmission reset"
Also, remember that all things being equall you are penalized with a 200 lb weight dis advantage to the E. You might overcome some of that by taking everything out of your car including the spare, jack, tools and any junk you normally haul around. Last but not least, run your gas tank down to about 1/4 full.
All of the above should even the scales some.
Be carefull.
Old 12-15-2006, 10:38 AM
kenstudios's Avatar
The E will beat you period. Both have about equal performance but consider the weight difference. Tell him to fill up with gas but you make the run on empty, remove spare tire, jack and anything that adds weight. Dont forget your camera, we want to see this. Good luck.
Old 12-15-2006, 04:27 PM
fusion2007's Avatar
thanx for all the help guys
kenstudios i will definitly post pics and a video of this.
bamberger man im tryin to prove to this guy that he should stop talking smack about our s classes. yes i know everyone here knows that s class is already superior but he doesnt. and im gonna show him whos car is truly better.
sprink49 thanx for your advice im looking that up right now. if theres anything else i can do as a quick tune up to help myself out ill do it. and also that guy does not know of the Adaptive transmission reset so will that advantage help me. and also is there any like notification of the reset can i hear anything?
any other advice is greatly appreciated
Old 12-15-2006, 04:46 PM
newton22's Avatar
BMW E39
The "ECU reset" (BTW, I don't like to use that term to refer to the procedure as it actually does NOT reset the ECU in my opinion, but rather trick it to believe that you are driving aggressively, therefore the ECU will provide you will optimal shift points and throttle response) does little. I have done it numerous times and sometimes, you will feel a difference, but nothing that will win you races.
The S-class is extremely easy to drive in a straight line. Unlike high powered AMGs, we don't have traction issues. But I can give you these tips:
If accelerating from a standstill -
1. Turn ESP off and leave the shifter in Drive (also make sure you're in S or Summer/Sport mode).
2. Apply the brake with your left foot firmly
3. Lightly and gradually apply the gas with your right foot just a bit (or until the RPM holds at around 2000 rpms). This is called brake torquing.
4. BE SURE to never brake torque for too long (like holding the car like this for more than 20 seconds). This will heat up your torque converter and that is bad. I wouldn't know why you would want to brake torque for that long anyways. It usually takes about 2-3 seconds.
5. Drop the brake and punch the gas quickly.
6. If executed right, the car will chirp the rear tires, the ESP will flash for a few moments and you're off.
If accelerating from a roll (in motion) -
1. Leave ESP on (or off, it doesn't matter).
2. MANUALLY select a gear that will run the engine up to more than 3000 rpms, but no more than 4500 rpms. For example, if racing from a 20 mph roll, use first gear (first gear is strong). From 40 mph, second gear. 60 mph, 3rd. Punch it from that gear and manually go through the gears. BE SURE to watch your tach, and shift BEFORE it reaches redline (Our motors don't make optimal power at redline anyways, but it the gas is floored, the motor will run to redline).
3. After the race is over, shift her back into Drive.
And Ken is right, you have a slim chance. The E is a few hundred pounds lighter. But worth a try. Don't throw money into this one.
Old 12-15-2006, 04:50 PM
kenstudios's Avatar
You can also check all your fluids, clean or change your airfilters to ensure unrestricted air flow, check tire pressure and when your are ready to race, warm your car and tires up well. It may not make that much of a difference but you'll get better results. Good luck and keep us (me) posted. I like pushing my S to it's limit.
Old 12-15-2006, 04:53 PM
fusion2007's Avatar
yeah good idea.i also like pushing my car to its limit. iv heard cleaning your maf sensor can help too?how do i get to it?
Old 12-18-2006, 02:03 AM
Almost a Member!
SLR N8's Avatar
2006 S500, 2005 Honda Accord Hybrid, 2004 Chevy Suburbin, 1986 Toyota pickup, 1984 Toyota Supra
I know I'm only 14 and all that, but I have watched races and know pretty much what I am talking about. I have been in a few races in an s500 myself (I'm not driving ofcourse). Believe me. The torque on an s class is strong. You should reset the adt (adaptive transmition), but don't take that chance. Before the race run your s class aggressivly around the freeway at half tank. Your adt would be set. Make sure you are in sport. Also mut your suspension at sport 2 mode. It puts the tires more firmly on the ground to give off a better push. When the race starts get a little momentum before flooring the accelerator. Good Luck! S class rules! Period.
Old 12-18-2006, 08:00 PM
fusion2007's Avatar
yo newton thanx for your advice. the gear shifts points really help. i had no idea our engines were this strongn can first gear really go up to 40? and the guy im racing its his first benz and he thinks he knows everything there is to know about a benz. if u have ever drivin an e class have you noticed that it feels kinda sluggish when you shift into drive?
and
slr n8 thanx for your info too. ill definitly do that.and i agree: S CLASS RULES!!!!!! since im running on comfort tires the michelin mxv4 hes probably got 17 or 18s wat evers stock non an 04 e500. im not sure if the s class will loose traction even if you floor it from a complete stop?
will it?
Old 12-18-2006, 08:21 PM
HLG600's Avatar
R230 SL63 | W220 S55
The ECU tip actually works, tried it out several times on my car after driving in traffic and it was noticeable. As for the sport setting, I recall reading somewhere that for straight-line acceleration, the comfort setting optimized weight distribution. As the other members said, 1/4 tank of gas, no spare, and correct tire pressure will give you a slight edge.
Good luck, have fun, and stay safe!
Old 12-19-2006, 02:47 PM
fusion2007's Avatar
thanx man!!! i will and ill be sure to buckle up for this one
Old 12-21-2006, 07:35 AM
sprink49's Avatar
2004 S500
OK....so let's do it already.
Old 12-24-2006, 11:22 PM
fusion2007's Avatar
its gonna be in jan
Old 12-25-2006, 02:21 PM
fusion2007's Avatar
Be carefull.
in step 1 when you say turn to on. do u mean turn to on with the engine cluster lighting up with all the lights on it or to the on position where only the white lights in it come on?
Old 12-25-2006, 02:42 PM
newton22's Avatar
BMW E39
All the Christmas lights light up.
Go ahead and try it, but differences will be minimal.
Old 12-26-2006, 02:55 PM
fusion2007's Avatar
i think that means with all the lights in the cluster light up ill try it!!!thanx newton
Old 12-27-2006, 11:07 AM
benz300's Avatar
trying to defy laws of physics ?
e500 with the same engine has a lighter body and better acceleration numbers. s500 is not comparable. why bother comparing apples and oranges ?
but sure go ahead and let us know what happened
Old 12-27-2006, 02:46 PM
fusion2007's Avatar
your forgetting a major advantage the s class has..traction!! when i floor it ill hold the ground immediately it wont slip. he thinks that by turning off the abs system he will go faster but actually he will loose traction and his wheels will be only burning rubber.
Old 12-27-2006, 03:06 PM
newton22's Avatar
BMW E39
Can't turn off ABS unless you're in dyno mode. If you mean ESP, we all know Mercedes ESP stays on even when its off. The E500 isn't a AMG, it won't kick loose. A little tire chirp and it'll quickly take off.
Not to disappoint you, my money is on the E (unless the driver was half-awake or something and you got a big jump).
Old 12-28-2006, 02:12 AM
Almost a Member!
SLR N8's Avatar
Since you have some racing experince and your friend has no experince, might as well race with manual shift mode. You control the transmision. Your friend will probably do the same but shift at the wrong points. Just be a smarter driver.
Old 12-28-2006, 05:04 PM
newton22's Avatar
BMW E39
As long as the pedal is floored, the car will shift right before entering the redline, whether you want it to or not. This doesn't apply to some AMGs and newer Benzes, but it does to these cars.
Unless racing from a roll, never use (semi)manual mode. It's slow.
Old 01-03-2007, 04:40 PM
Almost a Member!
SLR N8's Avatar
Ok. I see.
Old 01-25-2007, 08:44 PM
fusion2007's Avatar
victory baby!!! VICTORY GOES TO THE S CLASS!!!!!
Old 01-25-2007, 10:14 PM
sprink49's Avatar
2004 S500
Details????
Quick Reply: 2000 S500 vs. 2003 E500 (S class race against E class)
