Dash lights up with brake problem
Old 09-07-2006, 02:23 PM
avb777's Avatar
09 S550
Hello,
I have 2002 ML-320. When the card is cold and you start it all brake indicators light up: ABS. ESP. Brakes etc.
Once the car warms up and you restart it. It is fine.
Does anyone have any suggestions?
The car is out of warranty.
Thanks.
Old 09-08-2006, 02:51 AM
AndrewAZ's Avatar
BMW FTW
Originally Posted by avb777
Hello,
Thanks.
Not to be rude but this is a common problem and if you do a search it has been covered many times, you will be able to find the part number and someone has a DIY on the fix. Dont feel bad it gets asked so many times we should have a sticky for the topic....
Old 09-08-2006, 01:15 PM
avb777's Avatar
09 S550
I did do a search, and I did read about the brake switch. But the conditions are different.
Anybody has any suggestions?
Old 09-08-2006, 03:25 PM
AndrewAZ's Avatar
BMW FTW
My car did the same thing that your car is doing and it was the brake switch. When I would first start it in the morning I would get the lights, then in the afternoon when I drove it again the lights would be out. Had the switch replaced under warranty and problem went away, if I remember right the part is less than $20.
Old 09-12-2006, 12:34 PM
avb777's Avatar
09 S550
Just came back from the dealer and it turns our to be $2200 repair - control unit needs to be replaced. $1700 part. Not sure what to do now.
Old 09-13-2006, 10:30 PM
AndrewAZ's Avatar
BMW FTW
Ouch. That is probably the worst thing to go bad. Its not like a guessing game when they plug the computer in and it says the unit is not working so my guess is they are 100% right. Its up to you if you want to replace it or not but i dont think ESP or BAS work without it, you dont need either but they are safety features you might want especially for an SUV.
Quick Reply: Dash lights up with brake problem
