AC clutch relay location
Old 04-22-2006, 10:13 AM
kicker's Avatar
E320 2000 w/GPS
Does anyone know where is AC clutch relay? My A/C compressor is not running, since it's low on freon so A/C clutch is not kick in. I try to load freon into it, and I wasn't able let out the freon on the low pressure side. Does any one knows how? I am trying to use the freon with the dye so I can see where the leak is...
thanks
Old 04-22-2006, 10:32 AM
Richard / E320's Avatar
2001 E320
thanks
I can't help you with your question, but was wondering what size wheels you have on your 'E' and do you have any other pictures of your vehicle on a web site for viewing?
Thank you-
Old 04-22-2006, 10:39 AM
kicker's Avatar
E320 2000 w/GPS
Carlsson 2/6
Thank you-
Hi,
Those are Carlsson 2/6 brilliant edition 18". currently they are in the wheel repair shop. Firestone nicked couple of them when I replace my tires. so I had a wheel place powder coat them on all four wheels so they will match each other. they are 18x8 and 18x9. I might be interested selling them in the future.
Old 04-22-2006, 10:52 AM
2001 E320
Hi,
Hello Kicker;
I recently switched to 18" AMG Style III's, so I was interested in your wheel size due to the lowered look. Did you lower and if so, what specifically did you do? I have been looking at H&R and Eibach springs to lower mine approximately 1.25" or so, and yours caught my eye. Any other photo's?
As you can see, it needs a little lowering...
kicker's Avatar
E320 2000 w/GPS
My economy button
thanks
by the way my "EC" economy button is not working, and always lit on. I guess becuase no freon and to shut off the compressor and clutch is off.
Old 04-22-2006, 10:53 AM
kicker's Avatar
E320 2000 w/GPS
My economy button
thanks
Old 04-22-2006, 10:58 AM
kicker's Avatar
E320 2000 w/GPS
vogtland spring and koni shocks
Hello Kicker;
yes, I lowered with vogtland spring and koni shocks, I'll try to find some pic for you on the PC for you. it did lower quite bit, I also had to replace the spring pad at the rear to #1 give it a lower look.
Old 04-22-2006, 11:02 AM
2001 E320
Thanks for the information; I'll look forward to some photo's, as your 'E' looks really sharp.
Now hopefully someone will answer your original question...
Quick Reply: AC clutch relay location
