SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Cigarette Lighter broken
Old 04-11-2006, 11:08 PM
SlickIvy's Avatar
'99 SLK 230
Hi all
On my 99 SLK, the console cigarette lighter does not work. At first I thought it was the things I was plugging in (chargers, etc), then I checked the fuses (they're all ok), so it must be something else. The lighter itself does not work either, but I never noticed before since I do not smoke.
I'm thinking it might be a loose wire. Is there any way to access the back side of the lighter to check for loose connections?
Thanks for any thoughts/suggestions/fixes!
Old 04-26-2006, 12:39 AM
troyconwell's Avatar
Mine is broken too
I tried to use a cigarette lighter charger for my cell phone and found that mine didn't work either. I haven't torn anything apart to fix it.
Old 04-26-2006, 10:14 PM
DickB's Avatar
'99 SLK 230
You have to have the key switch on.
Old 05-06-2006, 06:39 PM
SlickIvy's Avatar
'99 SLK 230
It doesn't work with the car running either. is ignition=on what you mean by key switch?
Old 05-08-2006, 06:31 PM
DickB's Avatar
'99 SLK 230
Yes, that's what I meant.
To remove the console for access on a manual shift car, you pry off the shift boot and then the trim piece that surrounds it. (Doing this from memory. I think the automatic is similar.) That will expose a couple of screws that need to be removed. Next open the console storage lid and look for a flap in the bottom liner at the back - this is very difficult to see. That will expose two nuts that need to be removed.
Quick Reply: SLK/R170: Cigarette Lighter broken
