Check Engine Codes will not clear 2001 E320
Old 01-11-2006, 08:10 PM
purplegrog's Avatar
2008 E350 Wagon
I've recently had check engine light codes thrown for cylinder misfires. I changed my plugs and went back to autozone to get the codes pulled/reset. When I tried to reset the codes, the tool they were using said it was erasing the codes, but for some reason the codes stayed. Does anyone know why the check engine codes would not erase using a standard OBD II tool? I'm driving a 2001 E320 with 92000 miles..
Old 01-11-2006, 08:37 PM
Clk&Slk's Avatar
06' Clk 500 Cabriolet, 01' CL 55, 00' Clk 430
If the code is a "hard code" (meaning, major misfired) then only the dealer can erase/reset the code.
Old 01-11-2006, 10:06 PM
purplegrog's Avatar
2008 E350 Wagon
so, is a cylinder misfire inherently a "hard code"? or are there degrees of cylinder misfire about which I need to be concerned? Also, is there any reliable way I can test the spark plug wires myself?
Old 11-15-2006, 11:38 PM
Almost a Member!
Top Jimmy's Avatar
'96 E320
Multiple Misfires
I too recently had a Multiple Misfire error code after getting a rough idle and the dreaded CEL. Auto Zone read and cleared these for me so my experience was that a Multiple Misfire error was NOT a hard error code.
As for checking the plug wires - use a multi-meter that and check the resistance in each... there should be little or none.
Best of luck!
Old 11-16-2006, 04:17 AM
Clk&Slk's Avatar
To a degrees of cylinder of misfired. " hard code" usually will trip the "limp mode" to protect the engine from damages. The cheap hand held code reader from Autozone will not be able to reset the code.
Old 11-16-2006, 07:54 AM
RobertG's Avatar
things with and without wheels
Best of luck!
spark plug wires will have resistance value somewhere in the 2kOhms or more per every foot of wire
Old 11-19-2006, 10:57 PM
starbrite's Avatar
2004 E320
Did you by any chance get the code values written down ?
Quick Reply: Check Engine Codes will not clear 2001 E320
