S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
sounds like snow tires on the front....
Old 08-11-2005, 04:43 AM
kevinrea's Avatar
2002 S500
hi guys,
i am experiencing a road noise that seems to be coming from the front of my 1990 560SEC.
It sounds like if you had put snow tires on the front of your car/truck.
I thought it might be the tire itself, so I rotated the tires., but the sound is still up front.
I am thinking wheel bearing, or because a sound can really transmit through a chasis and can be hard to pinpoint.., maybe carrier bearing on the driveshaft ?
It doesn't seem to change in volume or pitch when I turn., and if I take the transmission out of gear while rolling, it is still there.
Does it at all speeds.., does not seem to get much louder with higher speeds.
any ideas out there ?
thanks,
kevin
Old 08-14-2005, 04:59 PM
MBHustla858's Avatar
front wheel bearing
Rate This Thread
Rate This Thread:
Quick Reply: sounds like snow tires on the front....
