SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: SLK230 Need Help with Dashboard Lights, EC, ESP
Old 08-03-2005, 09:19 PM
DangerTruong's Avatar
2002 SLK230
I am a new owner of a 2002 SLK230. I bought it used and so there was no drivers manual included. I never look at the things anyways, but I do have some questions on the car. Any help would be very much appreciated.
1. What is EC? Is this the same as Air Conditioning?
2. What is ESP? There is an "ESP OFF" button, and I am wondering when to push it.
3. One button has a picture of a car with a tow hook and the word "off". What is this one for? I assume I push it when I need a tow.
4. I have attached pictures of the right and left dashboard light indicators. Could someone tell me what each of these symbols mean? I can recognize windsheild wiper fluid, oil, check engine, emergency brake, battery and seat belt. What are the other cyptic symbols?
5. How do I toggle my fog lights? I've attached a picture of the switch, but I have no idea what the little green and red symbols on the bottom left signify. I can't turn the switch to select these, and they aren't buttons either.
6. How do I engage the "Airbag Off" button/light?
Thanks a million for the help!
Attached Thumbnails SLK230 Need Help with Dashboard Lights, EC, ESP-dash1.jpg   SLK230 Need Help with Dashboard Lights, EC, ESP-dash2.jpg   SLK230 Need Help with Dashboard Lights, EC, ESP-lights.jpg
Old 08-04-2005, 08:24 AM
TLC 320's Avatar
2001 SLK 320
Try this:
http://forums.mbnz.org/forums/forums...168490&posts=6
You need the manuel for topics such as how to raise teh top by hand, and lots of other topics.
Old 08-05-2005, 11:18 AM
wedmonds1's Avatar
Smile
I believe EC is "economny mode" which, when turned on actually means your Air Con is off.
Active Safety Systems: ESP
ESP: Electronic Stability Program:
Increases stability when cornering by helping to control oversteer and understeer
cannot remember and dont have my manual to hand
Lights are turned on by turning the switch, dim & normal
Fogs are turned on by pulling the switch toward you.
There is a button but i have not done anything with it. Not done anywork on dash to want to turn it off.
Not the full sp but at least a start.
Old 08-05-2005, 04:18 PM
bazzle's Avatar
Glove box manual etc
Parts list and R170 tech files on here under files. http://www.r170.org/files/
Glove box manual on here. http://www.virgeweb.com/rage2/slk_r170_manual.zip
resetting service display here http://eerola.home.comcast.net/auto/MBSLK230Kdiy.html
SLK how too.. http://www.slk32.com/pages/gotopages/howto.htm
Here you go matee
Bazzle
Old 08-05-2005, 04:22 PM
bazzle's Avatar
Also you dont engage airbag off button itds only a check light.
Green on fog (pull switch when past off) is front fogs, red is rear fogs.
EC turns "off" the aircon pump.
Need to turn "off" esp (asr) when towing or rear wheels will lock up due to traction control being activated due to front wheels not turning and rear turning. Vehicle thinks you are havine a prob!
Bazzle
Rate This Thread
Rate This Thread:
Quick Reply: SLK/R170: SLK230 Need Help with Dashboard Lights, EC, ESP
