Front and Rear SAM's
Old 07-15-2005, 07:31 AM
Qletis's Avatar
2002 Mercedes Benz C230 Turbo Kompressor (310HP and 325ft-lbs of torque)
Are these the front and rear SAM's?
Ok the front fuse assembly is
Mercd # 209 545 11 01,
5DK 008 485-11,
0000 02 301 15 1126 03 (6),
Q;03 HW: 2603 SW: 4802
Rear numbers:
209 545 07 01
5DK 008 486-11
0000 03 297 15 1535 02 (5)
Q: 02 HW: 2603 SW: 4802
Small box attached to rear unit
A 211 820 91 26
Delphi
510 08 042 0
Q 03 ID:43
HW: 0701 SW: 1501 RW: 4303 LNR 031048 P211-02
Old 07-15-2005, 11:43 AM
SUNILP's Avatar
2015 E250D
The small box is probably your tow sensor. There are several part numbers for front and rear sams depending on the build date of your car. I have a rear sam in stock if you need.
Old 07-15-2005, 11:49 AM
Qletis's Avatar
Ok the front fuse assembly is (Control module SAM)
209 545 11 01 (bad number?) (Mine is 002 545 94 01 $268)
5DK 008 485-11,
Rear numbers: (Fuse box control module SAM)
209 545 07 01 (Old $234) (Mine is 203 545 32 01 $322)
5DK 008 486-11
Small box attached to rear unit (Which I don't need. Cant this be seperated from the SAM?)
A 211 820 91 26 (Alarm module $87)
Delphi
510 08 042 0
Q 03 ID:43
Quick Reply: Front and Rear SAM's
