removing interior trim
Old 06-19-2002, 04:44 AM
jpau's Avatar
w203 silver sedan 240
Question removing interior trim
Hey all,
I was wondering if anyone had any experience successfully removing the interior trim to their C's. I am looking to trade my wood pieces for the aluminun sport trim. I am just trying to get a feel of how difficult this job could be. I've worked with cars for a while but dont want to risk the chance of damaging the fragile interior pieces. Any suggestions or help is greatly appreciated.
j
02 c240
Old 06-19-2002, 09:08 PM
Admin Alumni
MB-BOB's Avatar
See Garage
Removing the center console wood and trim around the radio is not hard. Do a search on "wood console," and for "Changer installation" for instructions.
However, your sedan has wood trim on the doors. I don't believe anyone has posted on how to remove these pieces. It might look silly to replace the center wooden pieces and not the door bits.
If I ever were to buy a Coupe, I'd replace the aluminum console trim with wood, but there are no door trim pieces to worry about in the coupe, so it would be an easy job. But not so for the sedan.
Old 06-23-2008, 08:17 PM
02W203HOUSTON's Avatar
02 W203
does anyone know how to remove the interior wood trim pieces in a sedan? I have searched with no luck, any help would be greatly appreciated.
Old 06-24-2008, 10:05 AM
02 W203
Nobody knows? When you swap out for the carbon fiber and aluminum trim, are you guys taking it somehwre to be done?
Old 06-24-2008, 10:16 AM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Session has a fairly detailed write-up here. https://mbworld.org/forums/showthrea...ighlight=radio
The pics don't show up for me now, unfortunately, but his write-up is good.
Which parts are you looking to replace? If the center console, in brief, you remove the area around the shifter first, then the ashtray, then work your way up. As session says, the hardest part is getting to the screws around the air vents, etc. Otherwise, it's mostly tugging, and being not afraid to use enough force to pop them off.
Old 06-24-2008, 10:27 AM
e1000's Avatar
a quarter mile at a time
If you're going for all the trim pieces, the front doors are the hardest part.
Old 06-24-2008, 12:16 PM
02 W203
yes I had seent hsi in the DIY thread, I was looking to get the info on the door pieces as well. I tried to pry them cause they looked similar to how my old 330 trim was placed but it started to crack so I am not sure what the best way to remove them is. Thanks for your input guys I will keep searching.
Old 06-24-2008, 12:37 PM
///AMG4EVER's Avatar
CLS55 Designo 030
Here you go. Post #25 & #26.
https://mbworld.org/forums/c-class-w203/134887-how-do-i-remove-door-panel.html
It's fairly simply, just be careful with the clips when you pull the panel.
Old 06-24-2008, 12:57 PM
02 W203
https://mbworld.org/forums/showthread.php?t=134887
so the door panel has to come off before I can pull the trim off. I just was not making that connection. THanks for the info.
Old 06-24-2008, 02:07 PM
Mu9enx's Avatar
01' C32o
funny thing is, i removed my trimtoday. the center console/ashtray/headunit are the easiest, but the damn door.. that's the area that pisses me off. after you do one door the others will be so muxh easier and quicker to do. then the trim are another story; those damn clips are feckin annoying!
Old 01-05-2017, 07:03 PM
miike's Avatar
2002 G500, 1961 190b, 2001 SL500 Sport
Do you have to take the whole door panel off to get the wood trim off?
Quick Reply: removing interior trim
